1999 grand am 3400
dwsracing
Mid Michigan
Not seeing this question in past posts, the cooling fans, when you start car cold on fan comes on then second one comes on. As car warms up the shut down. Backwards lol. All I have done at this point is check and clean all connections/ plugs. Any thoughts?
dwsracing
Mid Michigan
do you have the AC on when you are observing this?
No heat/ac both were off. The AC sensor on passenger front by radiator was unplugged cleaned with electrical spray, blower dry dry and hooked back up, as was the heat sensor plug. I have done no testing of anything, not my strong suit.
18,903
37
48
you have a EGR problem and the computer maybe turning on the fans to prevent any damage that may occur from overheating.
dwsracing
Mid Michigan
Had a friend say the same thing today, any ideas how I proceed? In the meantime I will search old posts.
