2000 GP GT won’t crank
Colton Purchase
I moved my 2000 Gp into the garage to fix some lights and then when I went to pull it out it won’t start. It won’t crank or anything the battery is good but as soon as you go to start it everything goes dark until you let off the ignition can anyone help?
20,497
141
63
Do you have a voltmeter?
20,497
141
63
Check the other end of the battery cables, the starter and the ground.
