bonni black
I have a 2000 ssei with a 4T65E-HD trans
the car will move in first and second gear but will not move if shift selector is in 3rd or overdrive.
if i drive down the road start with shifter in second the car will shift from 1st to second and i can shift to third at about 35-40 mph and it will shift. then i can shift to overdrive and it will shift into that gear and continue to climb in speed but when you come to a stop the car won't move unless you put it into 1st or 2nd.
I would be thankful for any help or input.
