2000 Sunfire, issues, $500, South Carolina
columbiawifi
224,827 miles, 2.2L
A/C and heat work
Several tires in new condition
Issues
Sounds like a valve or timing chain as it coming from right under the valve cover and toward the accessory side of the motor. Was able to get it home and it might could be driven a short distance
Needs new motor mount(s): Noticed the engine shimmys some
Exhaust leak a little past the manifold. Probably shaken loose due to the bad motor mount
Poor suspension
Paint doesnt look great and could use some cosmetic work on bumpers
Dash may not look great in the pics because I removed part of it for stereo install. I'll include the bezel and you should be able to put it right back on
Warning lights related to ABS. (Brakes still feel as strong as ever..so no concerns there)
Drivers side door does not shut smoothly, needs minor adjustment
