2002 brake lines
ddahlgren
SE CT
Had to change the one that goes left to right on the firewall a few years ago and now one under the center of the car blew out last night. What happened to split braking as I did not lose rear brakes lost all brakes.
Is this going to be an easy fix or do I need to buy a pre bent line from the dealer? I have to get it up on stands though can't get it in the garage as the Corvette is up on stands so down to no cars right now.
Does anyone know what it looks like off the top of their head or if a piece of straight tubing from NAPA will go from end to end where it attaches? If straight line will work a diameter and length would help.
Dave
ddahlgren
SE CT
Called the dealer today and they claimed it is 3/16 brake line, I would imagine with bubble flairs and a bend it yourself part. They said they have changed a lot of them and locally the salt is so bad they have had to trash rotors and calipers too.
For fun asked the service department on how much to change the line and bleed. 3 to 400 plus towing to get the car there.. Yikes lines and fluid is under 40 bucks retail but hey for tubing that is 89 cents a foot and they need 4+ a foot. I imagine 8 bucks of brake fluid must be 50 at those rates. I will fininsh the Corvette and pull the Gand prix in the shop thanks..
18,787
30
48
are you a member of Club Corvette of Connecticut?
ddahlgren
SE CT
I am not a member where are they located? I was thinking a while back about joining a local club that was fairly active but they disbanded fell apart whatever. I did not really fit in as hey were all about show and wax and I own a well loved driver class car though looked better than some that were at the shows.
18,787
30
48
I see you are in SE CT, I'm in Danbury and belong to Candlewood Valley Corvettes. Club Corvette of CT. is the largest CT club and is based in Branford, CT. So I'm not sure which one is closer to you. Since Club Corvette of CT is very large, maybe 300 members there is a broad base of interests. Candlewood has about 60 members and at this point the membership including myself are in you age group. We go for Sunday back road cruises to lunch destintations, an occasional car show to support the club running the event, and various other activities. My 69 is a driver with over 200k miles.
ddahlgren
SE CT
The club you are in sounds like the one we had around here. Same activities about the same size maybe smaller. Mine is a 91 coupe ok car and have had it for 11 years now. I am a bit terrified the next issue to come up is going to be the heater core LOL. Just changed the water pump and finishing the air pump delete. The previous owner had under drive pulleys and found a set of original ones in good shape so doing that as well. All the under drive ones did was make the engine run hot and alternator not charge at idle..LOL I have done a ton of work to it and still have some things to do and debating keeping it or selling it to be honest. It is a low miles car with around 75k in 27 years.
18,787
30
48
I did my heater core decades ago, luckily it is a non-ac car making it a little easier.
