Please consider whitelisting my site in your ad blocker. If you must keep it running here, please support this endeavor and select a support plan - which starts at only $0.16 cents per day. I'm not asking for much. I just need a little help. Thank you.Click here to select a support plan.
2003 Pontiac Bonneville I can run the car for about a hour and the cars gets a high idle about 2- 2,500 rpm. I've replaced the IAC,TPS,MAP,MAF and it still does the same thing any suggestions
