2004 Grand Am Won't Start
Corykll
ok everybody here is something that I am hoping ya'll can help me with; I have a 2004 Grand Am SE1 3.4 V6 that till about three months ago I have had no problems with except a rear head gasket. Well, I came home in it and parked it and when I went to get back in it.... NOTHING... All my dash lights come on like they always have but when you churn the jet to crank it.... NOTHING!! Needless to say I have replaced the starter, whole ignition all three parts, neutral safety switch, battery, Starter relay, and check all fuses. Still nothing. Just like the day I parked it. You put the key in and all the gilts come on like before but no start. The security light is on but not blinking. It usually goes off after I start the car, if I cloud start it. I have put in on an ODB and there are no codes. I have even went as far as pulling out the fuse box under the hood to make sure there is nothing burnt or melted. NOPE PERFECT!!! I know there is someone out there that has had this same problem and figured it out after all the cussing and fussing that I have been threw. I love my Grand Am and it has never put in on the side of the road. I think that is why what ever is going on with it waited till i park in in the driveway. PLEASE HELP!!!
kcstbb91
Dayton, OH
Reading your post and this is so me as well..I've r replaced everything you have mentioned including LIM AND the head. Check your drive belt for tension. If the tensioner pulley is too loose the car won't run. The bolt or hole could be stripped out check all. Are you getting spark? Fuel? Air? Compression? Sometimes you gotta step away from it for a min and have aggravation settle.
19,152
48
48
You seem to be replacing lots of parts but make no mention if you are doing any testing with a voltmeter or test light.
Did you bench test the starter before replacing it?
When you turn the key to the start position are you getting a voltage reading at the starter solenoid?
Corykll
I am not sure all i can tell you is that my brother came over and jumped it at the starter and made it crank. It ran for a dew seconds and went dead. We have checked everything that we can think of. Someone told me that it could be a SECURITY LOCK OUT since I replaced the whole ignition When you turn the ket to ACC before you start the engine security light is on but is NOT blinking. I ended up putting a whole new ignition in the car. Even got new keys. I was also told that it could be passlock feature as well. Ill tell you one thing. Whom ever invent that should be shot were they stand at. The car has been a great car. I purchased it from my step mom 7 years ago and all i have ever had to do to is is the heads and that was at 243,000 miles which was last year. Well and the regular maintenance. Other than that it has been GREAT!! I have 14 year old twins (girl and boy) and would love to pass it to my girl twin.
19,152
48
48
If you replaced the ignition switch along with the passlock sensor how did you program the ECM to recognize the new keys?
You never answered the questions concerning actually testing things with a voltmeter or test light.
You never answered the questions concerning test for fuel pressure and spark.
If your brother got it to crank and then it died, you have a dead battery.
