2004 Swaybar replacement
Bob
Does anyone know if the sway bar pulls out the right side when being replaced or does the car need to be jacked up and the bolts removed from the backside of the bracket that supports the motor after supporting it with a jack? Not finding a lot of info anywhere. Thanks
18,753
27
48
Check to make sure these instructions apply to your vehicle before starting.
  1. Raise and suitably support the vehicle.
  2. Remove the left tire and wheel assembly.
  3. Remove the pinch bolt from the lower intermediate steering shaft
  4. Loosen all insulator clamp attaching bolts.
  5. Place a jack stand under the center of the rear frame cross member.
  6. Remove the rear frame-to-body bolts.
  7. Lower the rear of the frame just enough to gain access to the stabilizer shaft.
  8. Remove the insulator clamp bolts and the clamps from the frame.
  9. Remove the insulators from the stabilizer bar.
  10. Remove the stabilizer bar links from the control arms.
  11. Pull the stabilizer shaft rearward.
