2005 e brake location
Redsunfire2005
Ok so I just tore apart my rear brakes and adjusted them and my e brake won't active at, the cables are fine I just need to know where the e brake adjustment is
18,758
27
48
did you follow the cable back from the parking brake handle to the rear and didnt see an adjustment buckle where the cable splits left and right?
92 Sunbird LE
Active member
Pull on the lever while backing up a few times, there is no adjustment to the lever at all like the old days....rear brakes must be adjusted first.
Hopefully you lubed up the adjusters before reinstalling.
Doug in P.R. šŸ˜Ž
