2006 Torrent Ignition swap pains
soadown45
Indiana
Ok gang I have a Canadian 2006 Torrent the reason I believe that is the Vin starts with 2. So the ignition cylinder wore out went to get a replacement cylinder instead got the cylinder housing and switch off of a 2006 Saturn Vue now my problem is this make a no crank, no start code. Since it is a Canadian import it has Pass Key III +. Should I put the old housing back on and buy a new cylinder or should I what.
