2007 g5
Paddy39
Nb
I recently had to change motor in my g5 car has manual transmission i change the motor but the motor came from a automatic transmission car so i had to change wiring but not computer now car works good but cooling fan does not work anymore what could be the problem should i get a fan from an automatic or it makes no difference thanks for help
18,682
21
38
did you test the fan with direct power to see if it works?
does your AC work and when you turn it on does the fan run?
have you checked the relay?
