2007: Parking, Tail and License lights not coming on!
vladhed
Ontario
Just noticed this - the lights that are supposed to come on at night don't - even when the switch is on Auto, Parking or Head Lights.
The switch works because the dash lights up.
Brake, turn, reverse and head lights all work as normal.
There doesn't seem to a fuse or relay controlling this, but rather 1 per corner, so I would expect to have some of them working.
Assuming it's not all 6 bulbs burnt out at once.
Anyone have a wiring diagram?
Thanks!
gah2180
Thanks!
vladhed, did you end up finding out what the problem was? I seem to be having the same issue, although intermittent. Also, when the brights function properly when switched on, the parking and tail lights function. However, when the brights don't come on when switched, the parking and tails will also not work. All my bulbs were changed, fuses look good. Could it be the turn signal switch?
