I recently purchased an 2008 Grand prix and the cigarette lighter doesn't work. Already replaced the fuse under the hood and nothing. And advice on what else could be causing it to not work?
did you check the fuse in the interior fuse box marked ONSTAR/ALDL ?
which fuse did you change in the engine compartment?
have you use a voltmeter to see if you have power at the lighter?
