An engine can't run without a throttle body. Either you misunderstood or something else is going on.They did, check codes is all I know. They said it ran without the throttle body and were sure that was the problem
You are correct, i dont understand,. If it's not the throttle body, remember it's new, what is my next step?An engine can't run without a throttle body. Either you misunderstood or something else is going on.
Have a shop test the pedal assembly or run actual tests.You are correct, i dont understand,. If it's not the throttle body, remember it's new, what is my next step?
Correct part? The Gm dealer had this car for over a week. I will call the back and write a detailed note about the tests the ran. My feelings are they " think" they k own just as we did because it's makes sense it's the throttle body with the symptoms but I doubt they did any further tests. They told me the drove it to get it to act up, but could not get it to die until the left it to idle for an hour. Once it did they " tested" the throttle body and were confident it was that part and wanted over 700 dollars to replace it.
They told me the saw it once it shut off for them, his exact words is he has never saw that center console throw out a warning like that.The P0172 code does not point to the throttle body. The work order says nothing about the message you receive on the screen. How would the technician working on the car know you had the message?
I showed them the above pic as well as it threw that message each time it shut off for themThe P0172 code does not point to the throttle body. The work order says nothing about the message you receive on the screen. How would the technician working on the car know you had the message?
If you Google it is very common. They should have looked at Technical Bulletins.They told me the saw it once it shut off for them, his exact words is he has never saw that center console throw out a warning like that.
I've googled this problem and it again points to the throttle body. I'm just at a loss as I've already spent money on the car and the shop telling me the problem is what I've already fixed. I spent the 80 on diagnostic with them and I don't feel like it's the correct problem.If you Google it is very common. They should have looked at Technical Bulletins.
I told you the peddle assembly would be the next thing to try followed by intermittent wire harness problem.I've googled this problem and it again points to the throttle body. I'm just at a loss as I've already spent money on the car and the shop telling me the problem is what I've already fixed. I spent the 80 on diagnostic with them and I don't feel like it's the correct problem.I appreciate you trying, I know impossible over the internet. Was Maybe hoping someone had the same experience that could say it's " probably this" before I waste more money or scrap the car.
Ok. I will try this next!I told you the peddle assembly would be the next thing to try followed by intermittent wire harness problem.
