2008 Pontiac Gp 3.8L stalling problem
Jasmine1988
When I drive my car randomly dies I can start it back up but he keep dying out also when I reverse my car shakes back and fourth and then dies out also my rpm needles jumps up and down . Can anyone help me to solve the issue ? Pleaseeee!
Do you have a check engine light on?
Are you upto date with maintenance, plugs, filters, etc.?
tobybill
crankshaft position sensor
Dan_in_WA
WA State
IIRC a bad crankshaft position sensor won’t throw a code if it fails. It’s like a heartbeat signal and is the only way the PCM knows the engine is turning over. Don’t know if that’s true for all makes.
Please correct me if I’m wrong.
G
G-211147
Thanks
