2009 Pontiac G3 will not start.
thetuckers1138
I know this probably isn't where I'm supposed to post this, but there doesn't seem to be any threads about the g3.
The car will not start when turned over. There's no "click", nothing at all. The lights and radio come on, but it will not even attempt to turn over.
The check engine light is on.
The battery has been tested and replaced.
The starter also tested good.
I've been told to check the ignition switch and that it could be any number of sensors. Any suggestions would be helpful.
Thanks in advance.
can you scan the computer for the code?
have you checked if there is a starter relay in the engine compartment fuse box?
if this is an automatic, does it start in neutral?
Detroit, Michigan USA
Hi thetuckers1138,
We recognize that you're trying to find tips on how to correct this issue and hope forum members are able to help. Our apologies that your car keeps cutting off and we understand how this must be frustrating. If you decide to take your vehicle into the dealership for a diagnosis, we'd be happy to reach out to them and stay involved if repairs are needed. Please continue keep us posted.
Amber N.
GM Customer Care
jw gtp
Thanks in advance.
I was watching that pawn stars show and the guy bought a jaguar that did something similar.
The mechanic unplugged the computer and plugged it back in and it worked fine.
