'62 Catalina Brake Booster Pushrod
_benz
OR
Hi All,
New around here and looking for advice. I am replacing the master cylinder on my '62 Catalina. After bench bleeding the new MC I've run into a problem during install where the pushrod from the brake booster has a plunger instead of the typical rod. Have I ordered the wrong MC or is the plunger able to be removed? All of the aftermarket MC's I've been looking at have the same configuration as the one I purchased. Any advice is greatly appreciated.
21,081
172
63
I agree, that looks like the piston from the old master, did the old master have a piston in it's bore when you removed it?
Brakebooster
Hi and Greetings from Finland!
We were strugling with that same problem yesterday and we also thought that it is the piston from the old master BUT we were wrong.
That plunger right there is connected to the brake booster with a pin located at the back of the brake booster. So in order to get one out is to unhook the pushrod from the brake pedal and remove whole brake booster from the body. After that we opened the brake booster and found that it was filled with dirt and liquids.
Here is few pics:
