67 grand prix new power window wont work, fuses are good any help
20,038
110
63
did you apply power directly to the motor?
did you check for power at the wire harness connector when the switch is moved?
G
G-973176
I have power to the window switch and power to the motor. The up and down part of the switch also shows power. I tried the new window motor on the other door and it still wont work. I think at this point the new motor is defective
20,038
110
63
Is the "new" motor really new, that is rebuilt or just from a salvage yard?
