73-76 HY code 15X6 wheels on a 62 Bonneville
boP
Anyone know if a set of HY code 73-76 Rally II Wheels will fit a 62 Bonny? 15X6, 5 on 5.
20,248
130
63
this site seems to indicate an aftermarket version of the wheel fits
boP
Running a wheel 2" wider than stock could create clearance issues. I want to keep the factory 15x6 wheel size and 215/70/15 tire to avoid rubbing the chassis, fenders, etc. So what I get from the above wheel fitment is 61-64 stands alone. Rear axle flange diameter, front bearing hubs and dust caps on a 62 could be a problem for a 73-76 wheel.
20,248
130
63
I used that as an example of a Rally wheel fitting, did not intend for you to install 8" wheels. If the HY wheels are local and your car runs do a test fit.
