73 Firebird Formula power steering
Formula1973
Massachusetts
Hi Everyone-
How do you diagnose power steering pump failure or box failure?
At low RPM it is difficult to steer. When under power and RPM's are up, steering is much easier.
Thanks in advance guys
Pete
19,442
67
48
Assuming the tires are at least 30 PSI cold and you have a full PS reservoir, a shop would install a pressure gauge on the pump to see if it is low.
