93-97 Firebird - Knock from rear end
Akula
Hello there,
Experiencing a single 'knock' sound from the rear left/driver side wheel while driving.
It happens on tighter left turns at low speed, and sometimes when pulling off/coming to a stop. Rarely, I will also hear it while changing gear, when downshifting.
Giving the rear driver side wheel itself a shake while parked up produces a bit of a clunking noise too.
I'm sure I'll have to get my head under there, but can anyone give me a few pointers as to what the culprit could be, and where they are on the car? I'm not too familiar with the suspension set up yet, which bushes wear etc.
Thank you for any help you can provide.
cammerjeff
Active member
748
50
28
Belleville MI
It could be alot of things, but I would
(1) check the exhaust system to see if it is loose and contacting any part of the suspension or chassis.
(2) Then look at the rear sway bar links & bushings
(3) Lower control arm bushings & the Torque arm bushing
(4) it could even be a loose shock
Good luck and please tell us what you find.
Akula
Brilliant, thanks Jeff. I'll have a look as soon as I get time. I have recently replaced both rear shocks so could well be a slightly loosened bolt.
I'll update when I've checked it over.
