96 Bonneville 3.8l Evap purge solenoid malfunction
meluckeycharms42
I need help I have a 96 bonneville SE 3.8l no supercharger. I got code p1655. Evap purge solenoid malfunction. I cant find the location of it so I can replace it. Can anyone help me please.
Have you looked on top of the charcoal canister which I believe is under PCM in engine compartment.
meluckeycharms42
Yes I found it is that the same thing cause it’s called a vent solenoid I’m looking for a Evap purge Solenoid
Have you already purchased the new part or looked it up in order to help you identify what it looks like?
meluckeycharms42
Yes. The Evap purge valve and the vent solenoid show up when I check autozone and O’Reillys. They both show those parts when I look up Evap purge solenoid. I’ve replaced the valve and I’ve already ordered the vent solenoid it looked old and rough. Only thing I can do next is drop the gas tank look their. I was hoping someone on here knew where the Evap purge solenoid is.
Look through this link
meluckeycharms42
The code I’m getting is a p1655. I looked at the link and tomorrow I’ll go ahead drop the tank and see if it’s their. I have not seen anything like a Evap purge Solenoid near my front valve cover I followed the lines from charcoal canister and I see no purge solenoid. So I’m going to look for it when I move my tank. The issue with This code is causing my car as I drive to start flooding out and cutting off then I’m stuck on the side road 15 maybe 20 minutes and it clears out and I can crank it up drive for a little while then it does it again and I can smell gas and it smells like it flooded and it smells like old gas in a way and I’ve have been putting new gas in
meluckeycharms42
Also thank you a lot for Helping me I hope you have a merry Christmas
meluckeycharms42
Did you remove the canister to see if it can be opened or replaced? A merry one to you too.
No but I thought about pulling it out cause it did have front end damage and the canister is in the front where the damage is
meluckeycharms42
I removed the canister and I see no damage or cracks. But it smells just like it did when the car would flood out. Makes me wonder if the vent solenoid was malfunction but I’m still dropping the gas tank in the morning to look for the purge solenoid
meluckeycharms42
I got another code reader that has a app to give more details. It now says I have a p1655 Evap purge solenoid circuit malfunction
Correct, it is either the valve or the wire harness connected to it.
meluckeycharms42
I removed the gas tank there is no evap Purge solenoid. I’ve looked everywhere. I replaced the vent solenoid and the Evap valve. When I look at the auto parts stores for evap solenoid nothing shows up as a part except for a valve or Evap valve and I replace both of them. If I can’t locate the Evap solenoid I can’t fix the code issue. I’m lost now on where to look
You either need a copy of the factory service manual or need to bring it to a shop.
