99 Bonneville SE turn signal flasher location.
Paul C.
OK hive mind, here we go. Turn signals not flashing. All respective bubs working, 4-way flashers working. I've located the 4-way flasher under and to the right of the steering column but I don't see another flasher unit anywhere, Am I looking in the right area (under steering column)? If the turn signal flasher is under there, I can't see it for all the wiring harnesses there. HELP! Thanks for your time and response.
Paul C.
Hi Doug, the left side of the dash doesn't have a panel/cover that comes off although a fuse box and it's cover are there. Sadly, there's no flasher on/in that box.
