ac 2000 gt6 gp
18,682
21
38
what do you have the climate control set for heat or ac?
if you have it set for ac, can you tell if the ac compressor is engaging?
if you have it set for heat, what does the engine temperature gauge show?
have you checked the coolant level when the engine is cold?
is the fan working on all speeds?
