Another coolant mystery
Laundry2002guy
Indiana
2004 Grand Am 3.4 . Coolant is disappering mysteriously. I can see a few drips here and there but no where near the amount needed to loose the amount i am loosing. NO COOLANT IN OIL thank God. I am baffled. From what I am seeing intake gaskets are suspect. Like I said though, no coolant in oil. I can see coolant under the upper intake sometimes. Thanks in advance for any help!:D
92 Sunbird LE
Active member
Yeah had the same problem on my 99 grand am 3.1 as many other people have had, need new intake bolts also with the gaskets.
GM bulletin recommends them.They should of issued a recall on this problem but never did.
Doug in P.R.:)
