Cant find headers/manifolds 79 catalina 400 swap
TheDripalina79
I have a 1979 catalina came with the 301 I'm putting a pontiac 400 in and I can't find headers that will work I bought Hedman shorty headers only to find they hit the sub frame and the brake line that runs along the sub frame I can't even find stock manifolds it's a column shift as well, A/c delete too can anyone help
22,508
316
83
I see no Hedman headers listed for your vehicle so exactly what did you buy?
If the headers were bent slightly would they fit?
Here are stock manifolds
TheDripalina79
Awesome, thanks and I bought just 400 headers that was not vehicle specific should've done more research. They might fit with some modification
cammerjeff
Active member
748
50
28
Belleville MI
I have a set of stock manifolds from a 1978 Catalina with a 400 available if you are interested. Any 77-79 Pontiac 350 or 400 manifolds will work if you can find them.
Where are you located? I would want $25 each plus shipping for them, They will need new down pipe studs as some of them snapped when removing them. Let me know if interested.
