Check Gauges Light
22,508
316
83
There currently is or was a reason for it to be on.
What happened to cause it to come on?
Zip
Member
35
8
8
The Coolant Temperature gauge reads low, but it does move up as the car warms...not much though. Was going to trace those wires as previously suggested.
92 Sunbird LE
62
48
Salinas, Puerto Rico
Thermostat in it? It's under the cap on the engine if it's a 2.0 OHC. Would read low temp if stuck open all the time or missing altogether...
Doug in P.R. :cool:
Zip
Member
35
8
8
Changed the sensor and the thermostat - gauge is now reading 140 to 160 consistently. Check Gauges light remains lit - is there a reset?
Zip
Member
35
8
8
A 198 degree one.. oem temp? Fan not running after a 1/2 hour at 80 mph on the highway and a 10 minute idle. Will check that next....temp stayed at just under 160 on the gauge.
