Clicyk Clack
18,912
37
48
There could be numerous reasons for that sound. I would start by noticing if it is coming from the passenger side of the engine which would be where the timing chain and tensioners are located. If it is do no wait much longer to have it fixed otherwise if something breaks the cost of repair will escalate.
Redsunfire2005
I was thinking injectors
18,912
37
48
use a piece of rubber hose to act as a stethoscope to determine where the noise is coming from.
