Coolant question
Horace
Just picked up a 2006 Pontiac Grand Prix. The coolant is green and I noticed it is supposed to be dexcool. Is this a major problem
Horace
It is low now should I just fill it with one of those brands or flush it first
92 Sunbird LE
Active member
1,909
16
38
Salinas, Puerto Rico
Check the radiator for buildup on the inner core, if there is ,then flush it.
If heavy buildup or rust, you can use vinegar then clean water.
You can get a coolant tester to check the old coolant, if the coolant overflow is low and it checks out ok, then just refill with new.
Doug in P.R. šŸ˜Ž
19,153
48
48
there are green coolants that are compatible with dexcool since you dont know what you have I would flush and refill.
