Cranks,but no start....,
jwhite72
2002 low mileage convertible w/WS6,6-sp.manual.Summertime driver up here in the North.Last time out Oct. 2020 cranked several times before starting-got out of driveway and stalled,wouldn’t restart-1/2 hour later few cranks and started-pulled back in driveway and idled for 10 mins-shut off and hasn’t started since. Replaced fuel filter,checked fuel pump,checked fuel rail pressure 60lbs,pulled plug wire and NO spark-where to next???
22,399
299
83
You have checked for any blown fuses?
Can you check for codes?
There maybe an ignition relay, swap it with say a fan relay to test it.
jwhite72
Will try the relay first-if not that I’ll have to buy a code reader.Local Autozone doesn’t have any to rent-Thanks,will let u know
jwhite72
Finally had a chance to work on it and u were right-ignition relay.Thanks,really appreciate the help!
