- Thread starter
- #1
staplerplease
2007 Pontiac g6 4 cylinder, number three not firing, replaced plugs, swapped around, checked swapped coils, check and verified good wiring, checked and swapped fuel injectors/checked wiring for them as well, issue stays with the same cylinder, checked the piston heads, the ones that work have a bit of carbon, to be expected, but the third one is wet with a lot of carbon, could the intake be dirty enough to cause this issue ?
