Data plate code help
Danla
WI
There are numbers and letters on my data plate that i need cyphered. After the build date is 0363. The car was built in Kansas and after Kan is 14309. At the bottom left , under the trim code is E 2EZG. Any help as to what these numbers are?
Danla
WI
Data Plate
Thanks Mel but there are numbers that weren't explained. On the example 67 plate, the build date code is 03B. What does the 1 represent? mine is 0363. After the plant code Pont, what does the 15xxx represent? And under the 223B, what does w 2LCR represent? Mine has E 2EZG.
18,672
E 2EZG
Group 1(the 1 is not stamped) letter E = Tinted windows
Group 2(the 2 is stamped)
Group 2 option E=Air conditioning
Group 2 option Z= 3 speed M40 transmission
Group 2 option G=console
15xxx=the daily production sequence
I believe the 1 is the shift.
Found this site, you have a couple of plate layouts for 67, choose the one you have and enter the data
http://datatagdecoder.com/
