EGR Valve removal
Nexia86
Germany
Hello,
my EGR valve is not connected, neither are the line that were connected to the choke of the Quadrajet.
Can you please take a look at the picture. Do I need to plug both lines (A) and also plug the EGR valve/cannister (B)?
I would think this would lower manifold vacuum if there are holes in the manifold...
18,667
Line A was part of a heated choke tube and has no vacuum in it.
Line B originally had a vacuum line from the carburetor connected to it, you do not have to close Line B.
cammerjeff
Member
436
Belleville MI
I agree, the only other thing I can add is Line B originally connected to the hot air stove pipe that is crimped off located in the circle of line A, not the capped vacuum port on the carb in circle A.
