Everything works but turn signals
soadown45
Indiana
Okay 2003 Pontiac Montana everything works on the multi position switch other than the turn signals. Hazards Cruse brights all work. Any ideas replaced the flasher relay and replaced the multiposition switch still have no turn signals everything works but turn signals
soadown45
Indiana
SOLVED: Make sure you check all the fuses that have anything to do with lighting. I took the time to check all my fuses and sure enough there was a blown one. Even though there is a turn signal fuse the system operates on many different fuses.
18,595
14
38
thanks for the update and glad you solved the issue
