mrbreezeet1
I am just trying to get all my parts together before I do the job.
As if I were to remove the brake lines and take them to the parts store then I will have no transportation.
l have a 2001 Grand Prix, just got it,
and somebody did a shoemaker job splicing a line in.
I have good brakes but there is a leak at both splices.
I just have to make sure my brake fluid remains full in the meantime.
I want to run the whole line eventually.
Does anyone know what the 2001 Grand Prix uses as far as the fitting sizes
At the under hood ABS unit, and at the brake hoses.
I had read in another group, they were 10 mm X 1.0 metric thread pitch.
However it seems like they're always has to be something I ran across a YouTube video where the follow was changing a line or showing you the where the lines go but he stated the line at the ABS unit under the hood, and the line at the rubber brake hose were different thread sizes on the fittings. (He was working on a 2004 Grand Prix. )
Did you know if this is the case on the 2001?
I know I did a complete brake line replacement on my 2002 Oldsmobile Alero and the fitting size at the ABS unit under the hood and the fitting size at the brake hoses were indeed the same size.
Does anyone know if the fitting sizes for the ABS unit and the brake hose junction on the 2001 Grand Prix are the same?
Have been searching a few hours already.
Thank you.
Thank you.
