Front seat
Hamhead
Does anyone know if the front seat from a 1966 2dr nova will work in a 1966 2dr tempest? I'm also looking at a seat out of a 1969 2dr chevelle.
Thanks.
Hamhead
Ok. The chevelle has same bolt pattern as tempest. So I guess it will work, I dont know about upholstering it so it matches my tempest interior. The nova has a different bolt pattern. I dont know if you can change the frame on it .
21,089
172
63
So you dont have the original seat?
Upholstery is available from Legendary and PUI
Hamhead
No. It came with a couple 67 gto seats. The car is a tempest so I'm trying to get it back to original.I have had no luck find a 66 tempest seat so far.
cammerjeff
Active member
638
30
28
Belleville MI
All post 1961 Tempests are bench seat cars, after 61 you had to order a Lemans or GTO to get bucket seats.
I think you need to limit your search to 64-67 A-bodies, they did change the floor pans for the 68-72 cars so I am not sure they will bolt into the earlier cars without modification. I would not buy the 69 Chevelle seat without double checking that it will actually fit. Just FYI
Hamhead
Thanks for the info. The chevelle seat is not too far from where I live. I plan on taking a look at it this weekend.
Hamhead
I got that 69 chevelle bench seat and it fits in my tempest perfect.🙂 He gave me the 3 point safety belts too and they bolted into my car as well! Does anyone know if the 3 point belts were standard in 1966?
21,089
172
63
The first year for mandatory belts was 68, they were options prior and they were not 3 point. Separate lap belt and shoulder belt.
Hamhead
Ok thanks. Then my car may or may not have had them from the factory. Interesting.
