guitarranger11
- Jun 20, 2011
Is there a way to pour gas directly into the motor of a 96 firebird. I'm not sure if my fuel pump is bad. Any suggestions on my problem. My car was running and I put a new tps in and it won't start or even try to start. I used my multimeter to test the tps and all the readings are normal. I put gas in just in case the gauge was off to no avail. There's no pressure at all at the fuel rail. Any help would be greatly appreciated.
