G6 Crank No Start
cruisesinc
Working on a 2006 G-6 2.4 litre. Will not start cranks has fuel pressure. Has weak ground on the injectors when cranking. Checked and cleaned all ground that I could find. Voltage side is good. PCM is grounding the injectors but very weak ground when it does. Thanks in advance
d
Do you have any codes?
Do you have spark?
How many miles on engine?
cruisesinc
No codes has spark and fuel pressure. We charged A/C shut car off . Went out later wouldn't start.
Did you pull any plugs to see if they are soaked in gasoline?
