Got a noise when I accelerate any ideas?
21,494
206
63
Could be a worn drive belt, a noisy accessory bearing or something major. Try to determine the source with the engine running and somebody gradually stepping on the pedal while you look under the hood or have it checked before the repair gets more expensive.
Jzamo
Would a head gasket make a noise like this? I was told it could be a loose pulley or something
21,494
206
63
Head gaskets dont make noise. The longer you wait to get it looked at the more likely something will fail preventing the engine from running.
21,494
206
63
Did you check the engine oil level when cold?
How many miles since you changed the engine oil and filter?
Jzamo
It had been a while since it was done, this car was given to me, so I’m not too sure. I know that they changed it about a month ago
21,494
206
63
Did you check the oil level when cold????
