Gtp comp g swap to standard gtp?
18,753
27
48
Spend tons of money for no purpose! You would at the very least have to change the following.
Red painted brake calipers.
Sport tuned suspension.
Heads-up display (also in GT2 model).
Paddle-style TAPShift.
StabiliTrak dynamic control system.
3.29 axle ratio.
Performance tires and Magnasteer II.
10-spoke light weight wheel.
Naynay
Obviously I'm not gonna convert the whole damn thing. Just transmission wise. I wanna take it from the 3:29 to the 2:93 that's in the standard gtp.
Naynay
I've been told the 05 gtp standard, came with tap shifters just like the 04 comp g. So my next question is why can't I take the ecm Pcm and transmission out of a 2005standard gtp and put them in my 2004 gtp comp g? Which will allow me to keep the shifters but also rid myself of 3:29 transmission. Does that sound correct?
18,753
27
48
Couldn't tell from your post that you were asking about a transmission. The part numbers for 2004 and 2005 transmissions are not the same. So mixing a 2004 engine with a 2005 transmission and then adding a PCM from 2005, there is no way of knowing whether that combination will be problem free.
