Gxp, 3.6l transmission wont shift and engine runs rough.
Devillover
Good afternoon everyone.
Pontiac torrent gxp 3.6l AWD.
Let's start with codes.
These 5 only came up once.
P2534.
P0031.
P0051.
P0030.
P0050.
These ones instantly show up when cleared and restarted.
P0752-----‐
P0458------
P0443 ____
P0010_____
P0020____
P0013-----
P0023--------
P2088 ____
P2092 ____
P2090____
P2094____
I replaced all the timing parts, oil pump, spark plugs, waterpump, and all gaskets except the head gaskets.
It ran great other then the transmission sticking in 2-3 gear once in while after the work.
Now it's running like garbage, and near zero power to move it and its stuck in 3rd and wont reset.
If the wave plate, torque converter, or solenoid A cause it to run like this?
Any ideas on things to check to verify what's wrong?
How likely is it that the transmission is fried?
21,089
172
63
Did you start with the lowest codes first?
You make no mention of the oil control solenoids.
The transmission codes are calling out solenoids also
Devillover
I did yes. I reused the camshaft position sensors and actuators, and couldn't find any breaks in the wiring when I went through the harness so those codes confuse me.
Devillover
Also. Compression test results.
1----140psi
2----140psi
3---150psi
4----140psi
5----150psi
6---140psi
