head light problem
uses.agent
on my 1995 firebird formula the driver side head light works fine. the passenger side will not raise. I have replaced the motor. I have checked both the new and old motor. both are fine. I guess i need to get out the multi-meter to see if I am getting power to the plug. My father-in-law said in his that he had it done it and it was a vacuum leak. could that be it? it looks to be all electric.:confused:
It's electric and yes you have to check the connector for power. Exactly what car and what year is your father-in-law referring to?
im not sure what car he is referring to. I checked the plug and im not getting any power to it. Im not even getting any continuity either. I guess I need to get a wiring diagram or something to find out exactly where the wires run. thanks for the reply
So... I have come to the conclusion that it is the head light control module. I didnt even know that there was one. but after doing some research, that is the conclusion that I have came too. im going to pull it off tomorrow and see what I can come up with.
