Head lights
Have you checked the taillight sockets for corrosion?
pontiacman1234
my gtp had a similar issue. if you can check the harness to see if anything has rubbed through. check extra at anything the harness goes through
pontiacman1234
what finally fixed mine was yanking on the harness and replacing the fuse since the legs had gotten too hot
