Idler arm replacement 63 catalina
Rob freeman
Can I replace my idler arm without removing the front springs? I have looked all around and it seems like the only way to get a wrench into the frame to remove the inner nuts is through the front opening, which is blocked by the front strut and spring? Am I doing this wrong? All the videos I have watched have had holes on the opposite side of the frame for reaching the nuts
20,805
161
63
Havent seen how it is set up on that vintage. Would assume there maybe a suitable tool to reach the nuts or the factory shop manual is still available and should be referred to.
cammerjeff
Active member
623
27
28
Belleville MI
I never had to change the Idler arm on my old 63 or 65 Catalina's. On the newer cars 67-90 there are 2 holes in the outboard frame rail to access the nuts via a long extension.
Sorry if you have already looked for this option and it isn't present.
mobileparts
Member
67
The application on this Idler Arm is 1963 - 1970 Pontiac Full Size -- All -- ONLY....
And the application for the CENTER LINK is ---- exactly ---- the same......
I personally don't work on cars, so I can't help you with that aspect -- but if that helps you any, then good....
( I also have them in stock --- BRAND NEW --- if you need them...)
Yours, Craig. 516 - 485 - 1935....
