looking for gm #19208659 sway bar bushing to lower control arm.
APVchet
Thanks for the research melsg5! But that bushing is for the frame to sway bar. The bushing I need is from the sway bar to the lower control arm. The sway bar goes from 26mm down to what I measure to be about 3/4 inch where the 19208659 GM part number goes. This bushing was used on quite a few GM FWD cars in the 90's.....but GM and everyone aftermarket seems to no longer make this PN. I am wondering what others have done to replace it.
21,503
207
63
again, you make no mention of the year?????????
APVchet
92 sunbird LE has the picture of the sway bar I have, the end of the sway bar bushings are smaller than the sway bar bushings that mount to the frame. If you look at the pictures you see that the end of the sway bar is much smaller than the rest. The part number 19208659 is the GM number for that end sway bar bushing. And it is a 1992 APV, but they were also used on the Olds vans, and earlier Pontiac vans. Thanks for your time.
All the scrapyards around here have gotten rid of these vans because not much metal in them to recycle.
21,503
207
63
found this list of vehicles that supposedly use it
1994 Buick CenturyCustom, Special2.2L L4 - Gas, 3.1L V6 - Gas
1993 Buick CenturyCustom, Limited, Special2.2L L4 - Gas, 3.3L V6 - Gas
1992 Buick CenturyCustom, Limited, Special2.5L L4 - Gas, 3.3L V6 - Gas
1991 Buick CenturyCustom, Limited, Special2.5L L4 - Gas, 3.3L V6 - Gas
1996 Chevrolet Lumina APVBase, LS3.4L V6 - Gas
1995 Chevrolet Lumina APVBase, LS3.1L V6 - Gas, 3.8L V6 - Gas
1994 Chevrolet Lumina APVBase, LS3.1L V6 - Gas, 3.8L V6 - Gas
1993 Chevrolet Lumina APVBase, LS3.1L V6 - Gas, 3.8L V6 - Gas
1992 Chevrolet Lumina APVBase, CL3.1L V6 - Gas, 3.8L V6 - Gas
1991 Chevrolet Lumina APVBase, CL3.1L V6 - Gas
1990 Chevrolet Lumina APVBase, CL3.1L V6 - Gas
1995 Oldsmobile Cutlass CieraBase2.2L L4 - Gas, 3.1L V6 - Gas
1994 Oldsmobile Cutlass CieraS, SL2.2L L4 - Gas, 3.1L V6 - Gas
1993 Oldsmobile Cutlass CieraBase, S, SL2.2L L4 - Gas, 3.3L V6 - Gas
1992 Oldsmobile Cutlass CieraBase, S, SL2.5L L4 - Gas, 3.3L V6 - Gas
1991 Oldsmobile Cutlass CieraBase, S, SL2.5L L4 - Gas, 3.3L V6 - Gas
1990 Oldsmobile Cutlass CieraBase, GT, International, S, SL2.5L L4 - Gas, 3.3L V6 - Gas
1994 Oldsmobile Cutlass CruiserBase, S, Special Edition3.1L V6 - Gas
1993 Oldsmobile Cutlass CruiserBase, S3.3L V6 - Gas
1992 Oldsmobile Cutlass CruiserS, SL2.5L L4 - Gas, 3.3L V6 - Gas
1991 Oldsmobile Cutlass CruiserS, SL2.5L L4 - Gas, 3.3L V6 - Gas
1990 Oldsmobile Cutlass CruiserBase, SL2.5L L4 - Gas, 3.3L V6 - Gas
1996 Oldsmobile SilhouetteBase3.4L V6 - Gas
1995 Oldsmobile SilhouetteBase3.8L V6 - Gas
1994 Oldsmobile SilhouetteBase3.1L V6 - Gas, 3.8L V6 - Gas
1993 Oldsmobile SilhouetteBase3.1L V6 - Gas, 3.8L V6 - Gas
1992 Oldsmobile SilhouetteBase3.1L V6 - Gas, 3.8L V6 - Gas
1991 Oldsmobile SilhouetteBase3.1L V6 - Gas
1990 Oldsmobile SilhouetteBase3.1L V6 - Gas
1996 Pontiac Trans SportBase3.4L V6 - Gas
1995 Pontiac Trans SportBase3.1L V6 - Gas, 3.8L V6 - Gas
1994 Pontiac Trans SportBase3.1L V6 - Gas, 3.8L V6 - Gas
1993 Pontiac Trans SportBase3.1L V6 - Gas, 3.8L V6 - Gas
1992 Pontiac Trans SportBase3.1L V6 - Gas, 3.8L V6 - Gas
1991 Pontiac Trans SportBase3.1L V6 - Gas
1990 Pontiac Trans SportBase3.1L V6 - Gas
APVchet
Looks like I may have to try the make my own method with the poly mix. Thanks for the help, I will post my results after I try it.
APVchet
So after trying the 'make my own' method and giving that up....I finally found a parts store that actually had a sway bar to control arm bushing IN STOCK for a 1994 Olds cutlass cruiser...I matched it with what I had and.......it was the same bushing..I had to burn the old bushings out of my metal brackets and reinstall them over the new bushings. Man its good to know parts are kept so up to date. FYI this bushing is a MOOG K6270. Thanks for everyone for their help on this .
