Lowering Springs??
M
maxtorque350hp
i want to lower my 95 sunfire gt to at least 1 in off the ground. Any body have suggestions what type or company has good shocks and springs?
J
jsdragonsoul
I can tell you to pay the extra money for good springs. Go cheaper and the ride will suck very badly eventually. Shocks im unsure about. Im just going to lower mine with springs and stock shocks.
9
95sunfireGT3.1
go with air bags you can have it sit on the ground if you want
N* ORphan
I thought I would add, make sure you have to front end realigned if you drop. Its going to through everything out of wack and youll chew your tires up with a quickness
J
jsdragonsoul
Yes realinement is very important. Remember that Bags require maintenance and lots of daily driving can be costly. On lowering springs Eibach is a very good brand. longer lasting without the annoying bouncing encountered in cheaper springs. Im sure there are others but Ive heard great things about Eibach.
M
maxtorque350hp
thanks guys
