Motor mounts
69elky
My friend has a 1968 Pontiac Catalina and he has had the engine rebuilt and is wanting to put it back in but it's one thing to replace the motor mounts wanting to know the best kind to buy
20,059
113
63
Try any of the chain auto parts stores, there is no brand that is going to be better than any other for a motor mount.
cammerjeff
Member
562
23
Belleville MI
Before purchasing any mounts, look at the side of the block to see how many Motor mount holes are there, you said it is a later 400 block, but not what year. If it is a 76-79 400 Block they usually only have 3 holes in them for what was considered Firebird Mounts. 65-69 Pontiac V8's had either 2 holes or 3 holes depending on the original application they were used in, 2 holes for Big Cars & Lemans, Tempest, & GTO's, 3 Holes for Blocks originally installed in Firebirds.
If the engine is a 1970-75 all 5 holes will be tapped and you can put them in anything without adaptor plates, if it is earlier it will not be an issue for the 68 Catalina, but if it is a late block it may need adaptor plates.
Here is a link to the adaptor plates you may need
69elky
Thanks, pass this along to my friend who is the one working on the 68
mobileparts
Member
56
Just seeing this posting....
I imagine by now , you've already sourced them....
If not, I have N.O.S. U.S.A. made......
Call me if you need -- Craig 516 - 485 - 1935......
