Need help Figuring out what is not working 08 G6 2.4L No start Good crank
MikeH
I have a 2008 pontiac g6 sedan 2.4L recently she craped out on me but the fuel pump runs and the engine cranks over wonderfully I purchased a fuel pump assembly thinking it could be the fuel regulator on the housing i havent gotten to replace it yet but I have no idea where else to begin troubleshooting. Advice would be greatly appreciated Thanks you.
Have you done a fuel pressure test?
Have you tested for spark?
Have you checked for codes?
Before it failed to start did you hear any rattling noise when starting or at idle?
MikeH
when it started at work there was no rattling it did have some white smoke and im not sure how to test for those on this car, i have a code reader does the car need to be on for it
mrbreezeet1
Normally, key on, engine off, to read codes.
The key has to be on to check for codes.
Either you have to look online how to run those tests or have a mechanic come to you or tow it.
You may want to do a compression test also due to the white smoke.
MikeH
fuel test is good 50-60psi
I tried to read the codes with a cheap reader but it didn't work so ill get them read soon.
once the things come in ill test for spark and compression
MikeH
shes got fuel air and spark and she will run BUT only with the pedal all the way down and even the shes at around 1kto 1.5k rpm wide open
i dont know what else to check
What happened to checking for codes and a compression test?
MikeH
i got a reader but it was a piece of shit and i dont really want to tow it just yet
i havent got the kit i need yet we wanted to see if we can at least get some fire in her so shes not sitting so long off
