Need help with 1968 bonneville front suspension
mobileparts
Member
68
Hey rocket --
1968 - 1970 IS 1000 % different than 1971 - 1972.
Newbie Tim G -- you rolled in on Oct. 13, 2019 and never came back.....
If you ever return, I have your entire front end BRAND NEW....
Upper & Lower Ball Joints, Upper & Lower Control Arm Bushings,
Inner & Outer Tie Rods and Sleeves, Idler Arm, and CENTER LINK,
Stabilizer Links & Sway Bar Frame Bushings...
Always best to simply call me --- Craig --- 516 - 485 - 1935... New York.....
44
Have some 68 - 72 B body complete suspensions lets not keep us all in suspence ,what assistance might you feel you may require ??
Tim g
Needs help but rather tight lipped about it
I tell all who'll listen & couple that don't..,, I need a delco remy 69 catalina starter with 1108333 # stamped in case...couple other # may due but th case will have a notch from end for starter lead , not hole drilled through it
