need help
glass man
first time doing this hope it is correct
i have a 59 which last summer i decided to change all the rubber and channels around the windows also change the power window motors regulator glass wire harness etc etc took it apart then started to put it back together unfortunately doing some work around the house i messed up my right arm had to have surgery do not have full use of arm haveing hard time trying to put it back together i was at a car show the other day in fl. someone told me there is someone in the greater boston area that just works on classic pontiacs he did not remember name or what town he was in if anyone knows please let me know or if there is just someone out there to help me put it back together
thank you
glass man
19,270
57
48
Being in Florida I cannt imagine why you are considering a shop near Boston. Using google I did a search for "car restoration florida" and came up with multiple shops. Find some near you and inquire concerning your needs. Good luck.
19,270
57
48
that makes more sense but same suggestion, lots of names pop up when you do a search on "car restoration massachusetts"
